WD9 experts
Posted by markloff on June 11, 2007 at 16:02:21 from (204.221.56.156):
Hello,
When did they change from the cast iron style radiator to the copper/fabricated style. Was it when they came out with the SWD9? I found out this weekend that I have one of each on my two WD9's. I know the copper/fabricated one is not original because someone welded nuts in on the side of the radiator to mount the front nose tinwork. Maybe it came from a TD-9 crawler? If I need to rebuild one is the cast one the one to rebuild? It sure looks a lot more durable to me.
Thanks in advance,
Mark
