Re: 46 bale pickup cylinder broken
Posted by CHUCK46 on June 11, 2007 at 20:33:02 from (64.136.27.229):
In Reply to: 46 bale pickup cylinder broken posted by zldwest on June 11, 2007 at 19:18:49:
Hi, Before you take anything more apart check every finger. The most common problem is that a finger gets bent to the side a little and locks itself into a band. Other than that it rides on a ball bearing on each end and has a cam with rollers on the inside end but they seldom cause trouble unless it has bailed at least 300,000. Good Luck, Chuck
