Re: Will an IH 574 operate a round baler?
Posted by brahmanhil on June 11, 2007 at 21:22:49 from (206.251.16.42):
In Reply to: Re: Will an IH 574 operate a round baler? posted by georgeky on June 10, 2007 at 22:09:32:
Thank you for your help. We blew out the radiator and transmission oil cooler today and they were plugged up. Also removed the front end loader and filled it up with hydraulic fluid. We rolled up hay with it today and it ran for 7 hours without boiling over. We thought we were going to lose a lot of hay without the 3010 and now we know we have a backup for it. We probably wouldn't have tried using it with the roller again if we hadn't been told it could be done. Thanks.
