Re: 46 bale pickup cylinder broken
Posted by zldwest on June 12, 2007 at 11:07:24 from (64.253.166.252):
In Reply to: Re: 46 bale pickup cylinder broken posted by Karl Hamson on June 12, 2007 at 07:31:42:
Thank you all for the replys.
I did check that one of the spring teeth wasn't catching and also took off the drive chain to the cylinder. I can rotate the cylinder less than 1/4 turn and it seems to hit something hard and stops, does it both ways. I can feel four of the five cam rollers on the ends of the pickup teeth bars by poking my little finger in through some slots. So that's why I was thinking maybe one of the rollers busted and it's catching inside.
I thought I could pull off the clutch assembly and take off a side plate to access the area. But so far I haven't been able to budge the clutch parts or get the side cover to move. Darn, I'd sure hate to have to cut it apart to get inside to fix it!
