Looking for the gas/distalate fuel bowl!!!
Posted by jonnny2006 on June 12, 2007 at 19:09:04 from (67.142.130.28):
Any one have/know of a fuel bowl assmbley that lets you hook to lines into it i could buy? the guy i seen with one laughed and said`"good luck" I would like to use my little tank for a reserve. he said he just leaves them both on and you can fill the little tank off the big. but i would like to keep it for a reserve as i go on the road alot with mine for cruises. plus i don't like looking in the tank to see when im about to run out.`if i had the small tank hooked up i would not have to check the big tank as i could just run out and switch over to the reserve and go to the barrle and filler up!. thanks guys
