Re: Best way to add 5 horse?
Posted by the tractor vet on June 12, 2007 at 21:06:04 from (75.19.120.214):
In Reply to: Best way to add 5 horse? posted by jonnny2006 on June 12, 2007 at 19:43:21:
Add highier compression pistons a 350 cam and head along with the intake and carb a littel govener work and a recurve of the dist , Oh you only wanted 5 horses
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
