Re: '50 M Transmission main shaftand seal removal
Posted by williamf on June 13, 2007 at 03:52:20 from (69.19.14.24):
In Reply to: '50 M Transmission main shaftand seal removal Adv posted by Sagebrusher on June 12, 2007 at 20:04:34:
No, you don't need to split the tractor. If you remove the clutch shaft you will be able to get the coupling off.
By the way, that sort of universal joint looking coupling that you already have off - the one with the four tapered bolts and the rubber parts in between? There's only one right way to put it back together and it's possible to force it back the wrong way. You can imagine how I'd know that.
Good luck, Wm
