Re: '50 M Transmission main shaftand seal removal
Posted by Jeff McBride on June 13, 2007 at 06:26:41 from (70.157.251.65):
In Reply to: '50 M Transmission main shaftand seal removal Adv posted by Sagebrusher on June 12, 2007 at 20:04:34:
Sounds like you may be able to do it without a split. Keep at it. I just changed all the gears in a 53 model and had to split it. The coupler on the mainshaft would not move. It didnt have a belly pump so I was lucky there. If you have the coupler moving on the shaft you should be able to get it.
