Re: NOS pistons for my H
Posted by Janicholson on June 13, 2007 at 09:58:58 from (199.17.6.137):
In Reply to: NOS pistons for my H posted by aaron b on June 11, 2007 at 20:17:33:
Here is the answer, and data source (science).
The piston needs to be installed with the offset in a specific direction. The rotation direction of the engine is key. The short side of the piston is always on the side of the engine toward which the crankshaft turns. Thus when the piston is just past true TDC on the crankshaft, the rod will be effectively straight down from the piston, gaining thrust advantage, and reducing the side pressure on the piston (a wee bit) at the point of peak mean effective pressure.
Measuring: Pull the piston pin part way out of one piston and put it in a vice (soft jaws) so the piston can be rotated around it. Spin the piston and measure to the side of the piston from a stationary heavy object placed for good stability. Then flip the piston 180 and measure to the same point. If they are so close that there is no difference with a careful measurement, then put them in either way but be consistant. If they do have offset, place the offset short side on the side of the engine on which the crank moves down when the piston moves down. I hope this helps. See below JimN
