Re: 1066 pop, pop,pop
Posted by Janicholson on June 13, 2007 at 15:58:27 from (156.99.211.221):
In Reply to: 1066 pop, pop,pop posted by IATim on June 13, 2007 at 15:21:48:
Popping in the intake system is more likely an intake valve. A diesel compression check is needed, or a leak down test. I would crack fuel lines loose one at a time to discover which cylinder. Then I would pull the valve cover and look at the springs on that cyl. if they are OK, I would loosen the valve rockers, and remove the pushrods from that cyl. Then use a rubber compression test adapter,or gutted old injector) to make an air fitting to put air pressure (100psi or more is OK) and listen for air escaping. If it is an intake, it will hiss through the filter as it seems to be doing. if it hisses in the exhaust, it is the exhaust valve, if in the oil pan, it may be a scored piston. Check it soon or spend bigger bucks. Best of luck, JimN
Home
| Forums
Today's Featured Article -
Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
