Re: Oil Capacity and filters for F-12 and F-14
Posted by Dave Allgire on June 14, 2007 at 07:46:03 from (24.217.111.191):
In Reply to: Oil Capacity and filters for F-12 and F-14 posted by migraine on June 14, 2007 at 07:19:12:
According to the original owners manual the F-14 with the IH engine will hold "approx. 5 1/2 U.S. quarts" of oil. I use a Fleetguard oil filter supplied by Rice Equipment #LF-584. If the supply house does not have that filter, they should be able to cross it over to another brand. You may have to add another quart to make up for the oil filter. The transmission holds "approx. 4 U.S. gals". The coolant system holds "approx. 3 1/2 U.S. gals". And the fuel tank is "approx. 12 U.S. gals". The worm gear on top of the bolster holds less than a quart. I use the same fluid as the transmission.
