Re: 6 - 12 Volt Generator
Posted by HENRY E NC on June 14, 2007 at 08:46:10 from (216.119.6.7):
In Reply to: 6 - 12 Volt Generator posted by Harold H on June 13, 2007 at 19:15:31:
A 6 volt generator usually puts out 7-8 volts and will work very well in a 12 volt system. So will a 6 volt starter. The starter will spin faster with 12 than with 6 V buts works very well. I have this setup on my M for several years with no problems . Sometimes I run it for 30 mins, sometimes for 6-8 hours and it works just the same. Might be a shade slower charging. BUt then, whats the difference between 5 or 10 minutes. John T is also correct.
I imagine they make 12 volt generators now because everything is no 12 volt( I have also dealt with several 24 volt systems over the years and used 18 volt generaters successfully)
