Re: Regular Fuel tank
Posted by Farmallgray on June 14, 2007 at 15:16:02 from (208.254.241.74):
In Reply to: Regular Fuel tank posted by Dan in Ore on June 13, 2007 at 11:08:40:
All Regulars had threaded caps from the factory.
I have seen a lot of them (including mine)with 1/4 turn caps but they apparently have had their tanks replaced. There were a lot of subtle changes and improvments on all the F-series tanks. The early ones on the Regulars must have been prone to cracking and or leaking.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
