Re: Super C Belt Pulley
Posted by leon on June 15, 2007 at 03:15:06 from (12.208.251.125):
In Reply to: Super C Belt Pulley posted by Wayne Mo on June 14, 2007 at 20:34:00:
Oil slinging around from the transmission and differential gears gets "pumped" into the housing that contains the belt pulley gears. Both the passage where oil gets into the belt pulley gears and especially where it drains back are pretty small so I suppose they could get gunked up
