Re: Super C Belt Pulley
Posted by Randy in NE on June 15, 2007 at 05:12:22 from (204.124.192.31):
In Reply to: Super C Belt Pulley posted by Wayne Mo on June 14, 2007 at 20:34:00:
There is a plug in the top the pto housing that you can add grease/oil through along with the one in the top of the transmission. You really only need to add oil to the pto sump when you change the fluid. Like Leon said, the rearend gears slop oil up into the pto sump. The pto sump probably holds about a quart. If the rearend is up to the proper level it should splash a sufficient amount of oil to the pto. The pto assembly is easy to remove. The gaskets and bearings are still available from Case/IH. I have the parts cd and can email you the page if you need it.
