Re: 2500 or 574 help (long post)
Posted by Janicholson on June 15, 2007 at 07:06:33 from (199.17.6.137):
In Reply to: 2500 or 574 help (long post) posted by chadd on June 15, 2007 at 00:09:44:
In addition to hueh's on target comments two items come to mind. The first is flow rating the hydraulics and checking to be sure it is not deadheading into a stuck, or misadjusted valve. The second is critical. If choking is needed, it is running too lean at the carb. this choking reduces the effective flow into the engine to about 60-70% (from the description you gave) . Further running lean will definitely cause excessive heat, in the engine and cab. Repair the fuel issue first as it can produce all the symptoms, and destroy the engine. JimN
