Re: 2500 or 574 help (long post)
Posted by Mike Van on June 15, 2007 at 10:48:27 from (24.151.104.209):
In Reply to: 2500 or 574 help (long post) posted by chadd on June 15, 2007 at 00:09:44:
I"d get rid of the cab in the summer, save a roof part if you need to for shade. If the 574 still has it"s own hydraulic system, the power steering is off those I imagine. That fluid goes through the lower part of the radiator to be cooled. If your external system is correct & all, you may need to add a cooler for that hyd. oil. Something really out of wack there, i"ve baled hay with mine when it"s been in the 90"s, I never had the engine run that hot.
