Re: 2500 or 574 help (long post)
Posted by caterpillar guy on June 15, 2007 at 16:08:59 from (152.163.100.197):
In Reply to: 2500 or 574 help (long post) posted by chadd on June 15, 2007 at 00:09:44:
THe radiator is still probably full of dirt try blowing it out with air. The pump you speak of is on the right side and was a factory option for those tractors for primarily industrial use but was available for the ag line also for just the purpose of running a loader and if you change it to run on the select control valves you'll be sorry for it on the loader operation slow as molasses (personal experience here) there should be a filter in the line for that external pump has that been changed. I do agree with the lean fuel running hot. Our 574 is diesel and is way to hot to set the seat for more than jus raking or loading. We tried using it for field work that ended fast the engine heat will run straight up on the gauge or just past on ours with the ambient temp your talking the grille will run it hotter if not kept brushed of regularly.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
