Re: H won't start
Posted by JFAVOR on June 16, 2007 at 20:34:02 from (152.163.100.197):
In Reply to: H won't start posted by Al Olson on June 16, 2007 at 10:43:13:
Sounds like the starter is locked. Put it in 5th gear and rock it until the fan moves. Or, loosen the two bolts on the starter until you can shake it. You should hear a click when you first move it. Tighten it back up and it will start.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
