Re: Funky serial #'s on M's
Posted by georgeky on June 16, 2007 at 22:05:57 from (205.188.116.138):
In Reply to: Re: Funky serial #'s on M's posted by Patrick Martin on June 16, 2007 at 22:00:23:
Yes that is what I mean. Your tractor has had them changed to standard axles. The MV and CH use a different drop axle. One is gear driven and the other is chain driven, but look nearly alike. The CH should have a single wheel on the front, that has been changed as well. However this tractor could even have the wrong number on it as parts may have been gotton from a salvage CH.
