Re: water pump 140?
Posted by Stan(VA). on June 17, 2007 at 14:37:11 from (4.248.255.154):
In Reply to: water pump 140? posted by baccerfarmer2 on June 17, 2007 at 14:09:41:
If you want it to go back together as it was, you need to go get a 140 or 240 block. As you are now seeing, the block casting changed between the 130/230 and 140/240 tractors. The front accessories all changed at the same time. If the block you picked up has the C123 ID cast in, it probably from a 100/200/130 or 230 tractor. The late Super A and the Super C also had the C123 block but it did not have the C123 ID cast in. If you want to keep this block, you need to go back and get all the assy's (water outlet at head, water pump, generator, fan assy, 2 seperate fan belts, and the radiator). If the crankshaft came with the block you already have the older style front crank pulley (wider belt), otherwise you need it. If you got a governor with the block you may also need the gov to carb arm from that tractor as they are different length.
Not impossible, but not a bolt in swap either...
Stan(VA).
Happy Fathers Day :)
