Re: IHC Cub Implements
Posted by Buzzman72 on June 17, 2007 at 16:24:56 from (4.224.252.113):
In Reply to: Re: IHC Cub Implements posted by tominnebr on June 17, 2007 at 15:29:13:
Best I can recall, to mount the moldboard plow the drawbar has to be reversed, the plow mounts to the drawbar, there's a link to the RH lift arm under the gas tank, and the drawbar is set up to pivot on the tapered-head mounting bolts. As far as the sickle bar mower, goes, the driving shaft mounts to two of the implement mounting holes on the torque tube housing, and to two rear holes. IIRC, there's a tube with oversize clevis-type ends that runs parallel to the pitman arm, and it's held to the driving shaft with a headed pin, to allow some flex in the mower itself [but not too much]. There's a rod with a loop connected to a solid square piece that goes into the square hole in the front casting, behind the steering, and it's held in place with a set screw, IIRC. A lift link again attaches to the RH lift arm that runs under the gas tank...and on the rod with the loop, there's a smaller-diameter rod with a threaded end and a nut with a handle that's used to hold up the cutter bar when the mower's in the transport [as opposed to mowing] position. Sorry I can't be more specific, but it's been about 30 years since I mounted a sickle bar mower on a Cub...and a lot longer since I've even SEEN a moldboard plow on a Cub. The ol' memory ain't what it used to be, unfortunately...at least in the case of the plow. But I'm pretty sure I'm fairly accurate on the sickle bar mower mounting. And the PTO pulley for the sickle bar has a pinch bolt to keep it tight...as opposed to the type with the two-bolt insert used on the Woods 42 for the Cub. Hope this makes a little sense, and hope it helps.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
