Re: 12 to 6 volt reducer
Posted by Buzzman72 on June 17, 2007 at 16:31:41 from (4.224.252.113):
In Reply to: 12 to 6 volt reducer posted by jeeper on June 17, 2007 at 13:38:10:
If you're converting a 6-volt tractor to 12V, you need to switch to a 12V generator and a 12V regulator. The 6V starter, with its heaver windings, should be OK as long as you don't crank it to death on 12V. You need a ballast resistor in the lead to the coil, unless you convert to a coil with a built-in resistor. If you're going to a negative ground system on 12V, you also need to reverse the leads on the back of the ammeter...and change all the light bulbs to 12V.
Not sure where you'd put a 12V to 6V reducer, because if you do it the way I detailed it, there shouldn't be any need for any further voltage reduction.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
