Re: Farmall belt pulley gearbox
Posted by georgeky on June 17, 2007 at 18:34:52 from (205.188.116.138):
In Reply to: Farmall belt pulley gearbox posted by johnfarm on June 17, 2007 at 11:47:12:
If one from a 450 diesel will fit I will go to the barn and check the number for you.
