Re: T9 Gas Engine Quit Now Coughs But Won't Run
Posted by KSmith on June 18, 2007 at 05:40:43 from (63.123.81.125):
In Reply to: T9 Gas Engine Quit Now Coughs But Won't Run posted by KSmith on June 15, 2007 at 08:31:22:
Thank you both for your help. I was getting good suction and spark as well as fuel to the cylinders. However, I picked up one of those in-line spark plug testers where you can watch the spark easier than holding the plug. Well the darn thing would spark for a while then quit then spark then a long pause. Note to self: check the most easy first. I disconnected the kill switch and the darn thing fired right up. I didn't even think about it. Needless to say she got a fuel system cleaning new plugs, points cleaning, air filter cleaning and some other misc fixin's. Thanks again!
