Re: Hydraulics and Transmission
Posted by georgeky on June 18, 2007 at 14:59:06 from (152.163.100.197):
In Reply to: Hydraulics and Transmission posted by TW1945M on June 18, 2007 at 09:42:06:
You just need to weld the end of the shfter up some and then grind it back down until it fits the notches in the shifting rails tighter than it does now. It is worn so much that it slips out when changing gears. As for the hydraulics, they have nothing to do with the tranny or rearend. Some add on hydraulic systems may use the rear end as a resivoir, but this is unlikely. It probably uses the belly pump for oil resivoir.
