Re: Seal inside brake drum on an H
Posted by Bob Kerr on June 18, 2007 at 17:40:45 from (205.188.116.138):
In Reply to: Seal inside brake drum on an H posted by PUTTER on June 18, 2007 at 15:16:29:
Just did those seals and bearings yesterday. I suspect you don't have the top cover off like I did, but I did have bad bearing there that cause the seal to leak and dumped bearing parts into the bottom of the housing. The seal number is 23184 and is an "SKF" seal if you have to have the number cross referrenced. I only put in one also, but if it leaks you can drive it back further in the hole and put in another one. The original seal is about an inch wide and has 2 lips. The replacement is rubber type and about 1/4 inch or so. There is a drain back hole at the bottom of the housing so if you use 2 seals don't block the hole off totally. The shaft that is in there drives the bull gears and holds up the differential so check it for slop. Mine was loose.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
