Re: 12v Generator
Posted by MikeinKy on March 21, 2009 at 08:17:45 from (68.210.188.18):
In Reply to: 12v Generator posted by Ohio H on March 21, 2009 at 07:44:08:
You will have to polarize the generator for the polarity that you want. The shop can tell you what to do. If the tractor is now pos ground, which it was originally, you will have to reverse the amp meter wires or it will read backwards. use the 6V starter, it will work real good, On mine, instead of using an inline resistor, I got a coil withan internal resister. OEM tractor parts has one that looks like the original one on the tractor, but it ain't cheap. Like the other guy said put in 12V bulbs or they will have a very short life.
