Re: OS6 clutch
Posted by Bob M on June 19, 2007 at 10:32:26 from (151.190.254.108):
In Reply to: OS6 clutch posted by Hand Crank on June 19, 2007 at 08:05:56:
I'm not familiar with the OS6, however I own a hand-clutched Minnie Mo "U" - it probably uses the same clutch as OS6. And from your description it sounds like the clutch needs adjusting. What's needed is to set the cluch mechanism so the hand lever "snaps crisply" over center. Too loose and it won't snap and the clutch will slip; too tight and the lever is difficult to snap and/or the clutch will not disengage. ---- Here's how the MM book says to adjust the hand clutch: Remove the inspection cover and find the adjustment ring lock pin (you may need to turn the crankshaft to bring the pin into view). Pull the pin out as far as it will go to unluck the adjusting ring. With the clutch disengaged, use a long screw driver to turn the adjusting ring. Turn the ring one notch at a time, testing the clutch lever action after each notch. When you get it so the clutch handle feels right, push the lock pin back in to secure the adjusting ring.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
