Re: Dropping Belly Pump on H?
Posted by Dan-Illinois on June 19, 2007 at 17:53:02 from (12.147.63.126):
In Reply to: Re: Dropping Belly Pump on H? posted by Wild Bill on June 19, 2007 at 13:53:43:
If you have removed the coupler drive from transmission to pump, all you need to do is remove plumbing from the side of tractor that is screwed into the pump and the cap. place a jack and some boards( I suggest having help but can be done by yourself) Then remove the bolts from the bottom eithe 4 or 6 bolts I can't remember.
A motorcycle jack would probably work better than a floor jack.
