Re: throttle adjustment on an H
Posted by Dan- Illinois on June 19, 2007 at 18:09:35 from (12.147.63.126):
In Reply to: Re: throttle adjustment on an H posted by HENRY E NC on June 18, 2007 at 15:16:47:
You will need to take the cover off the governor and adjust the low idle screw and the high idle setting screw. How to adjust it is in the service manuals from your farm stores. Your throttle linkage is connected to your governor linkage then governor to carberator.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
