Re: Farmall F-12 questions
Posted by Bob Kerr on June 19, 2007 at 20:25:08 from (64.12.117.8):
In Reply to: Farmall F-12 questions posted by 1031D on June 19, 2007 at 05:34:23:
Karl is right, you won't like it with the pulley on. The factory had a cover to slip over the shaft when not using the pulley. They may be hard to find though, but you should find one with patience. I had heard this before that a pulley could fly apart if hooked up with an overdrive. It will spin a lot faster, but not sure if they will break or not. I have an over drive, but took it off and I still had to drag my foot on top of the pulley so I could shift gears. Pulley is off now also but I work with mine, might be ok for a show to have it on, but don't let anyone hear you grind gears!
