Re: 706 hydraulic leak
Posted by the tractor vet on June 20, 2007 at 07:21:01 from (75.19.120.42):
In Reply to: 706 hydraulic leak posted by RandyWi on June 20, 2007 at 05:18:11:
Like the other guy said Ft. PTO input seal leak , now this can be cause by two things (1) the IDPTO ft. bearing is heading out to lunch , (2) the splines on the IDPTO input shaft are about half wore out and causen the shaft to wobbel . Like said tractor has to be split to fix takes about 4-5 hours if ya know what your doing to split and have back up and running with all the littel tricks that one learns over the years and has all the neat tools . Now if the splines on the input are woren then it is also wise on your part to replace the clutch and pressure plate and ALL the bearing while your there as if the splines are half wore out the the slines in the pressure plate are also wore and a new input and seals are only a band aid as IT will start leaking again before long. So if ya have to put a clutch in it the flywheel also has to be GROUND and the step on the flywheel has to be cut to keep everything in order.
Home
| Forums
Today's Featured Article -
Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
