Re: M needs you help
Posted by Owen Aaland on June 20, 2007 at 18:08:30 from (198.70.47.162):
In Reply to: M needs you help posted by jonnny2006 on June 20, 2007 at 18:03:18:
If all else is like it should be, check to make sure the venturi is not installed upside down. It is the aluminum piece in the middle. When properly installed the narrowest inside diameter should be even with the top of the main fuel jet. If it is installed upside down the engine will not run without some choke being applied.
