Farmall Tractors Discussion Board
Re: Oil leak-most likely location
Posted by Curt Cooke on May 13, 1999 at 19:49:23:
In Reply to: Oil leak-most likely location posted by mark h on May 13, 1999 at 14:00:26:
The most common culprit is the front crankshaft seal. This is not an expensive proposition but a messy and time consuming one. You can tighten some bolts on the oil pan but generally this isn't the problem.
Post a Followup
: Re: Re: Oil leak-most likely location
