Farmall Tractors Discussion Board
Re: Slowly dying Farmall A
Posted by big fred on May 17, 1999 at 11:25:17:
In Reply to: Slowly dying Farmall A posted by M.H. on May 17, 1999 at 10:48:20:
I agree with Red on the oil part, sounds like you might be using detergent oil when it wasn't used to it. The loss of power must be a fuel thing. I would suggest removing and cleaning the fuel outlet from the tank (an easy job, if rather messy and stinky), and if that wasn't the problem, check for little flakes of rust or (?) in the carb. Probably time for a carb rebuild anyway, after sitting for 10 years, possibly with gas in it.
Post a Followup
: Re: Re: Slowly dying Farmall A
