Posted by Janicholson on March 21, 2009 at 16:41:48 from (66.173.50.9):
In Reply to: W6 help, please posted by Gary from Va on March 21, 2009 at 16:29:51:
A chip of engine deposit probably got under a valve. I would check the compression again and see if one is a bit down. If it is, pull the valve cover and find the one on that cyl (exhaust) that is out of spec wide on adjustment. I would tap the rocker with a hammer several times to try to dislodge the junk if it is wide. )cold spec is .020". If the compression is OK, It may have cleared itself. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
