Farmall Tractors Discussion Board
Re: IH B-275
Posted by mj delaney on May 18, 1999 at 04:38:13:
In Reply to: IH B-275 posted by Kelly C. on May 17, 1999 at 11:16:15:
Not sure on the year, I'd say late 50's early sixties. Used to be lots of them around. Pretty good tractors. I used one as a teenager in late sixties, early seventies. Pretty good power, never liked the glo plugs or electrical system wiring. I believe they were a British tractor. The one I remember had Lucas wiring and gauges. As I recall, they had a really quick reverse 4 cyl diesel about 40 hp. There was a tap you turned to divert hydraulic oil from lift arms to loader. Came with a good heavy duty loader. About the same tractor as 35 MF. Still see the odd one around in Prince Edward Island, Canada.
Post a Followup
: Re: Re: IH B-275
