Farmall Tractors Discussion Board
Re: Re: transmission fluid
Posted by big fred on May 18, 1999 at 07:12:24:
In Reply to: Re: transmission fluid posted by Phil Auten on May 18, 1999 at 04:47:31:
The A uses 6 qts in the transmission and 3 pints in each of the rear axle housings (separate from the transmission and filled separately). I get mine from the local Cenex in a 2 1/2 gallon jug for about a third of what it would cost in quarts at the auto parts store.
Post a Followup
: Re: Re: Re: transmission fluid
