Farmall Tractors Discussion Board
Re: FARMALL M eng. number
Posted by Clint Hofstetter on May 18, 1999 at 11:46:14:
In Reply to: FARMALL M eng. number posted by Joe Scott on May 18, 1999 at 11:24:58:
Your serial no. would indicate that you have a C-248 engine, however a C-248 engine can be made into a C-264 by installing sleeves with a 4 in. bore and 4 in. pistons. This is accomplished by using thinner sleeves. A C-248 engine has 3 7/8 in. bore while a C-264 engine has a 4 in. bore. You need to check to see which sleeves and pistons you have.
Post a Followup
: Re: Re: FARMALL M eng. number
