Re: Super A Smoking
Posted by Janicholson on March 21, 2009 at 17:50:20 from (66.173.50.9):
In Reply to: Super A Smoking posted by Bud W on March 21, 2009 at 17:44:02:
If the crank is good and there is good oil pressure, a rebuild is not much more difficult than a head rebuild. The sleeves are Wet (they come out easily) and new pistons and sleeves will be in the 600 to 750 range with fluids and clamps etc. Doing just the head will not likely fix it unless it only smokes blue when idling, or going down hill in high gear with the throttle closed. If it smokes under load, it needs rings and the easiest is to use a Kit. Sold on this site, and other places as well. JimN
