Farmall Tractors Discussion Board
Re: Re: Farmall M Compression
Posted by RKS on May 20, 1999 at 02:31:04 from (152.201.154.10):
In Reply to: Re: Farmall M Compression posted by Terry Dixon on May 19, 1999 at 21:32:29:
Have read through I&T manual, can't seem to find the specs, although it does say that there were 3 different compression ratios on the M, depending on which sub-model it was I suppose. Anyway, your results are super, since the uniformity between the cylinders is what is important. Too, the valve spring load test for the non-diesel M is listed as between 105-110 lbs, which is a somewhat good match for what you are finding in the compression. RKS
Post a Followup
: Re: Re: Re: Farmall M Compression
