Farmall Tractors Discussion Board
Re: Farmall M Compression
Posted by The Red with Checkered flag. on May 20, 1999 at 04:32:37 from (216.192.170.32):
In Reply to: Farmall M Compression posted by JustinB on May 19, 1999 at 20:50:18:
Justin that is good compression. A very rough rule of thumb I use is take the compression ratio and mutiply by a factor of 17.5. Sounds like you have the medium compression. I think the early Ms were 5.9 to 1 and then the compression creeped into the lower 6s later on.
Post a Followup
: Re: Re: Farmall M Compression
