Farmall Tractors Discussion Board
Re: Re: Re: Re: Super A backfire after shut down
Posted by R.M. in Ont. on May 22, 1999 at 05:29:53 from (209.47.93.171):
In Reply to: Re: Re: Re: Super A backfire after shut down posted by How about on May 22, 1999 at 04:44:54:
Idling the engine for at least 2 minutes is the
way to go. The bigger engines should idle for 3
minutes before shutdown or serious damage will
result. Many big diesel truck engines are equiped
with a device which will shut them down after a
pre determined length of idle time.
The idle time gives an engine time to distribute
the heat evenly and avoids any local hot spots in
the engine.
Post a Followup
: Re: Re: Re: Re: Re: Super A backfire after shut down
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
