Farmall Tractors Discussion Board
Re: Re: Re: Re: Reversing polarity on a 12 volt regulator.
Posted by The Red with followup on May 22, 1999 at 08:29:40 from (216.192.167.121):
In Reply to: Re: Re: Re: Reversing polarity on a 12 volt regulator. posted by RKS on May 22, 1999 at 06:36:43:
Ok RKS I tried your idea. Left is pos. ground and briefly touched the gen. and batt. posts on the vr with a wire and got a spark.
Started it and it showed a little charge. Turned on the lights and it briefly went negative then went back to a light charge. So I removed the battery cable from the battery and she is still running. This is a high output generator and the battery is fully charged. So I reckon the regulator is just letting the generator charge as needed. If the generator were not working it would have died when I pulled off the cable.
Thanks for your help.
Post a Followup
: Re: Re: Re: Re: Re: Reversing polarity on a 12 volt regulator.
