Posted by D Slater on March 21, 2009 at 19:23:34 from (71.164.35.138):
In Reply to: Re: Farmall 1952 M posted by J S S on March 21, 2009 at 18:35:31:
Sounds like a nice tractor. Its also late enough to originaly recieved some other upgrades over most M. Bigger crankshaft diameter, Head and manifold changes to breath better, Larger outlet air cleaner and pipe from air cleaner to carb. Bigger bearing on transmission input shaft, sealed clutch pilot bearing in flywheel, thicker adjustable front wheel type hubs that fit rim with a closer fit. Bull pinion and differential bearings bigger and differential gears improved. Few other things.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
