Farmall Tractors Discussion Board
Re: Cub Quits When Hot
Posted by Mey(NH-50 Cub) on May 25, 1999 at 07:49:15 from (204.97.23.154):
In Reply to: Cub Quits When Hot posted by Bear on May 25, 1999 at 07:04:35:
Bear, Check the air filter system make sure it's not clogged up, especially that little tube that rune to the crankcase. You also could be on to something with the points and condensor, theoretically, the condensor either works or doesn't but can produce similar symtoms of a bad coil. Mey
Post a Followup
: Re: Re: Cub Quits When Hot
