Farmall Tractors Discussion Board
Re: Cub Quits When Hot
Posted by Walt on May 25, 1999 at 07:55:30 from (208.231.176.44):
In Reply to: Cub Quits When Hot posted by Bear on May 25, 1999 at 07:04:35:
I had this problem with my '64 lo-boy, after exhausting every other avenue I just happened to look at the ballast resistor, after removing it I found it to be cracked. My conclusion was it would get hot and expand thus opening the crack wider and breaking any electical connection. Does your cub have a ballast resistor? This would be connected between the coil and the distributor, if you have one on your cub you can replace it with a chrysler ballast resistor from the late 70's.
Post a Followup
: Re: Re: Cub Quits When Hot
