Farmall Tractors Discussion Board
Re: Cub Quits When Hot
Posted by RKS on May 26, 1999 at 02:42:29 from (171.212.16.171):
In Reply to: Cub Quits When Hot posted by Bear on May 25, 1999 at 07:04:35:
I would think your problems may be solved with new points and condenser, if you do it right. There may be a tad of contact material left on the breaker points which quickly overheats and doesn't funtion correctly. I had a Ford 600 that acted the same way, until I discovered the points were burned almost completely off, and all that was left was just a tiny bit more than the two point arms alone. Any engine can run amazingly good for a long time and then amazingly bad just minutes later and it be the points or condenser. Checking the ballast resistor is probably always a good idea, although from looking at mine on my H, it appears to be simply a very crude "current flow limiter" which either has a permanent "go" or "no go" condition. However, also remember that you have a myriad of "ballast resistors" on that tractor, one each at "every single wire contact" in the entire electrical and ignition system. They can act like you say, although I doubt a line break or open would behave exactly as predictable as you say - - "immediately crank and then again die." Line breaks that are very predictable are usually temp sensitive. Although, if you assume the coil and carb are ok, and you replace the points/condenser, and the problem continues, you will have to look for a line break, including in the distributor cap itself, rotor, and the high voltage side of the coil and plugs. My guess is the points fix it. Cheers, RKS
Post a Followup
: Re: Re: Cub Quits When Hot
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
