Re: Super a tires
Posted by 45M-meathead on March 22, 2009 at 03:15:13 from (216.237.226.1):
In Reply to: Super a tires posted by Ram4wd on March 21, 2009 at 20:04:40:
We have been running 11.2's on ours for years and it does great. It did speed it up which work out for us because we mostly use it raking hay and little odd jobs here and there, so lost of power is not an issue. If you use it for things that test it's power already then I probably wouldn't do it. I've even seen 12.4's on some but that is too much.
